NI TestStand
custom step description
When creating a custom step type, what do I need to enter in the "Step Description Expression" box to display the "operation" and "route(s) to connect/disconnect" the programmer has entered in the switching tab properties of each step? This custom step is only switching so i don't want to have to open the properties dialog and look at each step to find out what it is switching. Thanks, Jason
(2,969 Views)
Accepted by topic author jason1
Hello Jason,
In the "Step Description Expression" box you could do something like:
  "Operation: " +
    Step.TS.SwitchEnabled ?
        Step.TS.SwitchOperation==1?
            "Connect " + " | Route(s): " + Step.TS.RouteGroupConnect:
                Step.TS.SwitchOperation==2?
                    "Disconnect"+ " | Route(s): " + Step.TS.RouteGroupDisconnect:
                        Step.TS.SwitchOperation==3?
                            "Disconnect All":
                                Step.TS.SwitchOperation==4?
                                "Connect/Disconnect" + " | Route(s) Connect: " + Step.TS.RouteGroupConnect + " | Route(s) Disconnect: " + Step.TS.RouteGroupDisconnect:
                                    "Error"
    :"Switching not enabled"
It is a bit confusing because SwitchOperation is a number that corresponds to an operation so that's why we have the nested conditional statements.
Let me know if you have any questions.
Kristen
(2,948 Views)
