NI TestStand
Leave a step running possible in TestStand?
Hello all,
In the sequence editor, I have put in a few VI's.  Is it possible to leave the VI's running, move on, open another VI, move on, open yet another VI, and stop them all later in some other step?  I am asking this because one VI is responsible for outputting a signal in an FPGA, and another VI is responsible for measuring some signal from UUT that reacts to the signal from the FPGA.
And also, is it possible to change a local variable on the test sequence with respect to time?
Thanks.
(3,546 Views)
Yes, use the Run VI Asynchronously step type. Check Appendix E of the TestStand Reference Manual.
Regards
Ray Farmer
Regards
Ray Farmer
(3,537 Views)
Thanks for the reply.
Now, is it possible to change the local variables with respect to time?
(3,523 Views)
Dont understand! Do you mean you want to change a TestStand local variable from your VI while its still running?
Regards
Ray Farme
Regards
Ray Farmer
(3,507 Views)
Yea.  Something along those line.  I just need to some how change the values of the controls inside the VI while it is running.
(3,495 Views)
I'm not sure I follow...
Do you want to:
  1.  Change the value of the TestStand local variable from the VI that is running asynchronously? or
  2. Change the value of a control on your VI when a TestStand local variable changes?
Jervin Justin
NI TestStand Product Manager
(3,477 Views)
The easiest way is to use the TestStand - Set PropertyValue.vi ( this may not be the actual name but you should find it on the TestStand palette in LabVIEW). You will need the SequenceContext passed into the VI, the full lookup string to the TestStand variable eg FileGlobals.MyValue and the value you wish to set.
Make sure the TestStand variable is in scope i.e don't expect to set some Locals variable in MainSequence when you are currently running in a sub sequence.
Hope this gets you start.
Regards
Ray Farmer
Regards
Ray Farmer
(3,465 Views)
