Changing Local Variable to Test Name
I am trying to append a Local Variable to make it to the test name. I get the results to go into a CSV file, how would I be able to change a local variable to set it as a test name?
(3,203 Views)
Are assigning the value of the Local Variable to the test name or do you want to create a local variable with the name of the test?
BTW- what is Test Name in your context and where does it come from?  It can mean a bunch of different things in TestStand.
jigg
CTA, CLA
testeract.com
(3,161 Views)
I am trying to assign a local variable to become a test name
(3,129 Views)
Again, not sure where you are getting test name from and what it even means in your context.  That is such a loose term and can mean a myriad of things.  Are you talking about a step name?  or the name of your sequence file?  In TestStand terms what is test name?
Assigning a local variable in TestStand is as easy as:
Locals.MyVariable = "Test Name" in any expression.
If you want the name of a step: Locals.StepName = NameOf(Step)
jigg
CTA, CLA
testeract.com
(3,101 Views)
