Changing the report name at run time
Hi Aaron,
I'm trying to follow what your doing but do not have RunState.Caller.Locals.ReportPath in GetReportFilePath at run time. Would you mind posting an example sequence file? I can't tell if my report options are set different or what I am missing
My end goal is to get the report name then copy it to a different location using the Call Executable step, but I am stuck at getting the report name.
Pat
Message 11 of 14
(3,331 Views)
Pat,
Here you go. I really think the only thing you need is the GetReportFilePath Callback. I have the ReportOptions callback in here just to enable a report for every UUT.
p.s. You might get a type conflict when loading the sequence, I have some customizations made to the standard types, just use the default Types.
Aaron W.
CLA, CTA and CPI
Message 12 of 14
(3,314 Views)
Hi Aaron,
unfortunately your example has to be opened in TS2013. Is there a chance to get a TS2012 version? Or a textual explanation?
Thanks in advance,
Klaus
Message 13 of 14
(3,285 Views)
Klaus,
Saved for TS2012. Hope this helps.
Aaron W.
CLA, CTA and CPI
Message 14 of 14
(3,280 Views)
