NI TestStand
Check error in sequence file before execution - teststand api c#
Hi all,
I've modified the "TestStand UI with Native Control" example to automatically execute a sequence file but I would like to check the sequence file for any errors before it begins it's execution and throw an appropriate error.
How can I do achieve this?
ngupta4
(1,279 Views)
hi all,
I have done the below edits to the code:
this.axApplicationMgr.UserChanged += this.OnUserChanged;
private void OnUserChanged(object sender, NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_UserChangedEvent e)
this.sequenceFile = this.axApplicationMgr.OpenSequenceFile(this.sequenceFilePath);
if (this.autoStart == true)
executeButton_Click(this, EventArgs.Empty);
private void executeButton_Click(object sender, EventArgs e)
if (axSequenceFileViewMgr.SequenceFile != null)
axSequenceFileViewMgr.GetCommand(CommandKinds.CommandKind_ExecutionEntryPoints_Set, 1).Execute(true);
else
MessageBox.Show("You must open a sequence file before you can execute.");
I'm want to "analyze" the sequence file before the execute. How can i do that?
(1,234 Views)
