07-09-2014 04:54 AM
Just because this thread is closed:
http://forums.ni.com/t5/NI-TestStand/Disable-report-generation-API/m-p/2913362#M45903
I try to solve this problem in a new thread:
Add a Tab on a custom step type (e.g. duplicated a numeric limit test) with substep to enable / disable a record in report.
Respective to force it.
My attempt:
Types: MyTypes.ini --> Copy (e.g. Numeric Limit) in it--> Properties --> Edit Substeps
--> Add.. C/C++ DLL Call (Edit) --> then i tried the EditPassFailStep of the "CommonSubsteps.dll"
But dont work... , does not know how to use it neither i dont know whether its the right dll to touch...
Does anyone have a example solution for this problem?
09-11-2014 05:05 PM
Hi foxx,
Can you explain the exact problem you're experiencing?
CommonSubsteps.dll?
Please give us as much detail about what you want to do, so we can better help you.
09-29-2014 04:13 AM
Hi d-cubed,
i dont know how to do it.
As you are a NI engineer you can read the belonging service request: 7410380
But this:
http://forums.ni.com/t5/NI-TestStand/Custom-Edit-Sub-Step-UI/td-p/1567484
also does not resume
regards
07-13-2015 01:21 PM
Hi, foxx
I apologize for the long delay. However, after reading through the translated service request notes for 7410380, it is not clear to me what your goals are. Can you please explain in detail the functionality you require?
Thank you,
