Checking the status of Main Sequence in PostUUT callback
I am checking the status of the Main Sequence in the PostUUT callback, running TS 2014 SP1.
Say, the Main Sequence generates an error. In PostUUT I check the status and get the following
Parameters.Result.Status                 "Error"
Parameters.Result.Error.Code          <same error code as seen in Main>
Parameters.Result.Error.Msg            <same error message as seen in Main>
Parameters.Result.Error.Occurred    False
Shouldn't Parameters.Result.Error.Occurred be True? If not please explain why.
Thank you.
(4,204 Views)
Accepted by sukaba
In the process model the step that is calling MainSequence Callback is set to ignore run-time errors.  This is so that the rest of your Main Step Group can execute.  This is why it sets that result to False but retains all of the error info.
I'd trigger on the Status string if it were me.
Hope this helps,
jigg
CTA, CLA
testeract.com
(4,188 Views)
Thank you for your time.
(4,184 Views)
