NI TestStand
Class does not exist error
I have been experimenting with creating a custom step type.  That step type calls methods in a .Net assembly.  I have been adding, renaming, and deleting a lot.  Now I get the error below when trying to use a Pass/Fail Test step type.the above error.  At this point I have deleted all my custom step types, but the error remains.
Message : Module for Step 'Pass/Fail Test' not Loadable. Class '' does not exist in assembly 'Tests, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'.
File : C:\Projects\TestStand\CheckUpdate\MySequenceFile.seq
Location : Seq["MainSequence"].Main["Pass/Fail Test"].TS.SData
'Tests' is my .Net assembly.  Note that I have deleted all custom step types (from MyTypes.ini) that reference that assembly.  What is still referencing my assembly?
(3,045 Views)
When you place a step in a sequence file it copies the StepType to the sequence file as well.  Check the sequence file types and see if you have an instance in there.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,028 Views)
Try searching for the module name in that sequence file using the TestStand "Find" feature. Perhaps you are still using the step type or have a module specified with that assembly.
(3,000 Views)
