NI TestStand
Exclude Done and Skipped From A Datalog File (.txt or .csv)
Is there a way to programmatically remove skipped and Done steps in a datalog?  We have a PXI test station which numerous engineers use and so we are locked down how we can modify Database Options.  My log files are clogged with all this Skipped/Done spam, I find it hard to see the real test results.
Tony Jocius
Hill Rom
(2,308 Views)
Can you not use the filter options?
Can you not get the developer to switch off the record option for those steps you don't want to see in the report or database?
Regards
Ray Farmer
(2,273 Views)
