NI TestStand
Close Station Callback
Is there a way to setup a callback in the Process Model that is called when the user exits TestStand?
I don't see one in the default ProcessModel.
I guess I'd call it the "CloseStationCallback".
I have a LabVIEW program that is running concurrently with my TestStand sequences - I can launch it when I execute a sequence in TestStand for the first time, but I'd also like to be able to tell it to close down when the user is done with the system.
Any ideas?
(3,608 Views)
Add a SequenceFileUnload callback to your process model.
(3,607 Views)
Good idea, but I want to be able to switch sequence files without closing the LabVIEW Application.
That's why I was looking for a callback linking to the Station shutdown instead of the SeqFile Close.
(3,604 Views)
Are you switch process models or just sequence files.  If you leave Station Options>>Model>>Station Model set to the process model with the unload callback, it should work fine.
Also, it will not be a problem if you then load sequence files that explicitly require different models because the engine will keep the station model loaded.
(3,600 Views)
Cool Idea, thanks for the tip. I won't be changing Process Models.
So the idea is that when the application is closed, the ProcessModel Sequence File will be closed first, which will involve running the SequenceFileUpnload callback?
Makes sense - I'll try it.
SWEET. It worked, thanks.
Message Edited by 10Things on 01-17-2006 01:57 PM
(3,596 Views)
