NI TestStand
OCX not registered?
I have registered my .ocx using regsrv32 but it does not appear in the Automation Server drop list
in the Edit ActiveX/COM Call dialog box. When I browse to the file I get a message saying 'The type information
for <ocx name> is not registered on this machine.' What is wrong?
/Stefan
(3,072 Views)
An OCX is usually an ActiveX Control, so it would need to be attached to a parent form in a code module.  To utilize the control, you will need to create a code module and place the OCX on the form of that control, and call that module from TestStand.
Allen P
NI
(3,060 Views)
