Hello all -
Using the TestStand LabVIEW Operator Interface, I know that I can close all completed executions as a right-click option on the execution listbar control, however I would like to implement a button on the OI that would achieve the same effect. Or at least set the execution type mask so all executions auto close but I am wondering if the behavior is still exposed at a minipulatable level from the new API.
I am aware that there is a property 'ApplicationMgr.Executions' that takes the place of the old array of execution refnums (from TS 2.0.x OI) but it seems to only work when execution is paused?
I am looking for a simple way of retrieving references to completed executions at any time so that I can issu
e a close command to them without interfering with any current executions.
Any ideas would be helpful, thanks.
-Elaine
Cheers,
Elaine R.
www.bloomy.com
