NI TestStand
Error -17502 with MSG popup/custom fonts, DellTouch Hot Keys 2.10 is installed
I installed the Message popup with custom fonts in Teststand 3.0 and it worked. After I installed DellTouch Programmable Hot Keys 2.10 s/w get error -17502 when trying to edit the msg. Also I have another PC with XP,TS 3.0 and no Dell hot key s/w that get edit error
(2,950 Views)
Alan,
I think I answered another question for you on this same subject a little while ago. The link to that post can be found here. Is this the same problem that you are seeing? If so, were you able to debug the program and see what particular line is giving you the error?
Also, in your question above, I'd just like to confirm that you see the error whether or not you have DellTouch Programmable Hot Keys 2.10 installed.
Shannon R.
(2,950 Views)
