NI TestStand
How get the name of a TestStand step in LabView
I have a vi that is being called by several different steps in my teststand sequence. When the vi executes, I want it to indicate the name of the step. I tried using the "TestStand - Get Property Value.vi" but there doesn't seem to be an appropriate lookup string to get the step name.
TestStand 3.0 & LabView 7
(3,987 Views)
Wendell,
you should pass to the VI the caller's Sequence context (this should be done when you specify the step's module in TestStand). You should create a Step property from Sequence Context (right click to get the context menu), from which you should create a Name property. This is the step name you are interested in.
I have attached a sequence and a vi that demonstrates the result.
(3,987 Views)
