NI TestStand
Closing test Result panel without having to select the OK button
I am using TestStand 2017 and at the end of the sequence (Test UUT) the UUT Result panel require to select the OK button to start the next test. I would like the UUT Result panel to being displayed at the end until an IO change state and start testing the next UUT without the need of selecting the OK button.TestResultpanel.jpg
(1,136 Views)
Accepted by topic author JTTest1997
You have to modify the behavior of the PostUUT callback. It can be done specifically for a test sequence, by overriding this Callback in that sequence. Or globally by modifying (a copy of) the ProcessModel.
A very straightforward way of doing so should be to build a code module that will display the Pass status, and will wait for you I/O.
Mind to use termination monitor in this code module, to handle gracefully a potential Terminate in your code module. See Checking for Suspended or Stopped Execution within Code Modules
(1,094 Views)
