Command Line Arguements For TestStand Tools
If I run the UI from the command line like this:
I get this:
Now I want to create a tool.  So in the Sequence Editor I go to Tools>>Customize...  Then I add a command tool that points to the UI executable.  Then I try to pass it an argument like I did on the command line above.  -Help!  It doesn't seem to work.  I've tried with quotes, without quotes, with a space, without a space, etc.....  Ultimately I want to pass my selected sequence file into there.  Ideas?
jigg
CTA, CLA
testeract.com
Message 1 of 9
(5,479 Views)
I tried what you are doing and it worked for me. (TestStand 2014)
Make sure you are pointing to the exe file not the short-cut.
Ray
Message 2 of 9
(5,458 Views)
Hi Jigg
for your task, RunState.SequenceFile.Path will to the trick
regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 3 of 9
(5,455 Views)
Hi
It is not working!!
"/runEntryPoint \"Test UUTs\" \""+RunState.SequenceFile.Path+"\" /quit"
it is referenceing to privious loaded..
This works:
"/runEntryPoint \"Test UUTs\" \""+"C:\\Temp\\Test.seq"+"\" /quit"
at least adding is working in expressionfield!
Regards
Juergen
--Signature--
Message 4 of 9
(5,450 Views)
Accepted by ~jiggawax~
Hi Jigg
RunState.InitialSelection.SelectedFile.Path is doing the trick
Regards
Juergen
--Signature--
Message 5 of 9
(5,448 Views)
Thanks everyone!  I tried in 2014 and it worked like a champ.  I was testing it out in 2010 and it wouldn't work.  Any of you have 2010?  I'm curious now if it is just my machine.
jigg
CTA, CLA
testeract.com
Message 6 of 9
(5,431 Views)
Interesting thing I learned today.  The arguments field in 2014 and earlier does not allow expressions.  So I can't call Runstate.InitialSelection....
That must be new in 2016.
Crazytown!
jigg
CTA, CLA
testeract.com
Message 7 of 9
(5,418 Views)
Hi Jigg,
yes on TS2014 there is no expression button.
BTW if this would be my task, I would implement 2 additional sequnces  in my model
1. EngineCallback SequenceFileLoad for automatically updating the editors tools
    menubar with the sequence mention in 2. , because there are api-members
    allowing that stuff and menubar always fit's to your model's features.
2. Ordinary SequenceCall with only a Exe-StepType to call the UI
    with arguments's expression parameters.
Regards
Juergen
--Signature--
Message 8 of 9
(5,408 Views)
Thanks for the option.  There's a hundred ways to do this in TestStand.  I was hoping to get away with not using any dependencies.  In other words accomplish it simply through the menu.
Thanks for the help,
jigg
CTA, CLA
testeract.com
Message 9 of 9
(5,405 Views)
