NI TestStand
Conditional testing for runtime errors in Clean up
Hi all,
I have some code in CleanUp, which I don't want executed if a run time error has occurred in the Main sequence. It is possible to do this? I've noticed there's an option in the RTE window that pops up which allows the program to be terminated without running CleanUp, but I'd still like this to run if the test result is a pass/fail or if the sequence was terminated.
Appreciate any thoughts.
Bruce
Message 1 of 9
(4,656 Views)
You can do this by use of a pre-condition on the steps in you Clean-up. Have a Goto that will check, by use of AllOf, that an error has occurred in the main and if so jump the steps that you dont want to run.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 9
(4,644 Views)
Hi Ray
Thanks for your reply. I’m assuming this precondition in CleanUp would need to include a step error check for each statement in the main sequence? Is there any generic parameter I could test instead? I’m just wondering if it’s possible to avoid having to update this precondition, if the main sequence is modified.
Regards
Bruce
Message 3 of 9
(4,637 Views)
It probably depends if your Main Steps are set to run Clean-up if an error occurs.
If it does, you could use RunState.PreviousStep and check whether this has an error condition.
or you could use RunState.SequenceError but I'm not sure when this is updated.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 9
(4,633 Views)
Hi Ray
I just tried on TS4.0 :RunState.SequenceError
It is depending on your "Handle Error settings"
It is updated on "Run Cleanup"
and nothing is  done on "Ignore"
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 5 of 9
(4,624 Views)
Hi Bruce
Try this Example,
It parse the Errors in Cleanup
Note: this is only working on steps with are recored to result
Juergen
--Signature--
Message 6 of 9
(4,618 Views)
Thanks Ray.
Hi Juergen,
Any chance you could send that routine again in 3.5? Unfortunately, I'm haven't yet upgraded my TestStand.
Thanks & regards
Bruce
Message 7 of 9
(4,585 Views)
Hi
Try this one
Note: I dont know if a for-loop is running in TS3.5 so just try it .
Juergen
--Signature--
Message 8 of 9
(4,579 Views)
Thanks Juergen, that's great.
Bruce
Message 9 of 9
(4,548 Views)
