Container layout changed with adapter.
Why does TestStand container layout changes based on the adapter selection?
When using NumericLimitTest type with a none adapter the "Units" is visible.
But when using NumericLimitTest type with CVI adapter "Units" variable is not visible in Result container? Why?
Is it not correct that NumericLimitTest type Result container will always contain:
1. TS
2. Error
3. Status
4. Numeric
5. ReportText
6. Common
7. Units
8. Limits
9. Comp
Although TS container may change position.
CLD
(3,425 Views)
Does anyone know if there is a way to identify for a specific test if Units will be present in container or not? This is when traversing through a single result container in modelsupport.dll (c_report.c file).
CLD
(3,416 Views)
Accepted by lvrat
Hi lvrat,
You can use the TS_PropertyExists function to programmatically check if the "Units" property exists at a specified location using a lookup string.  This function is called several times in the program already, so you should be able to reference those calls for examples on how to call the function.
Justin D
http://www.ni.com/support/
(3,396 Views)
