NI TestStand
Control 6527 Card from TestSTAND
Hi Guys,
I want to control my 6527 Digital I/O card from TestSTAND application.
What is best way to do this? Can I use 'IVI Switch' or do I have to Create a LabVIEW VI for 6527 card and then call this VI from my TestSTAND sequence file?
If i can use IVI Switch how do i configure to see 6527 Device and select I/O lines required.
(2,802 Views)
This card is not a switch.  You will have to write a code module in LabVIEW, CVI, or another programming language to use it in TestStand.
(2,796 Views)
