06-07-2011 11:47 AM
Hi Guys,
I want to control my 6527 Digital I/O card from TestSTAND application.
What is best way to do this? Can I use 'IVI Switch' or do I have to Create a LabVIEW VI for 6527 card and then call this VI from my TestSTAND sequence file?
If i can use IVI Switch how do i configure to see 6527 Device and select I/O lines required.
06-07-2011 12:56 PM
This card is not a switch. You will have to write a code module in LabVIEW, CVI, or another programming language to use it in TestStand.
