NI TestStand
Controlling Test Sequence Flow from inside the ProcessModelPostStepFailure Engine Callback
When a Test Failure is detected within or TestStand System, the user must have the option to Repeat the Sub Sequence containing the failed step, Continue Testing or Cancel Testing.
Can I achieve this sort of control of the test sequences from inside the ProcessModelPostStepFailure Engine Callback?
Any ideas greatly received.
Regards
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
Message 1 of 20
(4,772 Views)
Yes, there are examples in TestStand/examples/callbacks that will help you.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 20
(4,751 Views)
Thank you for your replay Ray,
Unfortunately the examples use a callback inside the sequence file where as I am using a callback inside the process model.  I imagine the idea is the same but I am struggling to work out the correct property string for the sequence file NextStepIndex and StepIndex from inside the process model callback.  The closest I have got to anything useful is shown below.
RunState.Main.RunState.NextStepIndex = RunState.Main.RunState.StepIndex
Any thoughts anyone?
Steve
Message 3 of 20
(4,751 Views)
I just copied the contents of the SequenceFilePost StepFailure, Main and Locals into a ProcessModelPostStepFailure Main and Locals in \User\Models\TestStandModels\SequentialModel.seq.
Made sure I removed the SequenceFilePost StepFailure sequence from a copy of the example sequencefile and it ran as expected without any further alterations.
You should be using RunState.Caller.RunState.NextStepIndex = RunState.Caller.RunState.StepIndex
Regards
Ray Farmer
Message Edited by Ray Farmer on 02-22-2006 01:47 PM
Regards
Ray Farmer
Message 4 of 20
(4,746 Views)
Thanks for your effort Ray,
The only thing I am missing now is how to work out if the failure is from a Test Step or a Sub Sequence, as I only want to repeat Sub Sequences that fail.  I have been looking at RunState.Caller.RunState.SequenceFailed but it's no good.
Is there a Step Property that defines the step type (to differentiate between Test Step and Sub Sequence Step)?
Regards
Steve
Message 5 of 20
(4,739 Views)
Just re-read your original question.
To Retry the first step in the Sub-sequence you would set the NextStepIndex = 0.
This will set it back to the first step of the group ie Main | Setup |Cleanup depending where your failed step was.
If you what to set it back to the first step in Setup, then you would have to set, as well, the StepGroup = "Setup"
Hope this helps
Ray Farmer
Regards
Ray Farmer
Message 6 of 20
(4,738 Views)
You can try using RunState.CallStackDepth, if this is greater than 2, then its a SubSequence to MainSequence and you are in the Callback.
Regards
Ray Farmer
Regards
Ray Farmer
Message 7 of 20
(4,736 Views)
I am controlling the NextStepIndex in the Main Sequence to re-run my Sub Sequences and this is working fine.  It re-runs the entire Sub Sequence rather than the steps inside a sub sequence, which is important for the results file.
Please check my previous post for my remaining problem
Regards
Steve
Message 8 of 20
(4,734 Views)
Hi Ray
That would work for Sub Sequences of the Main Sequence which fortunately is all I need it to work for,  it doesn't seem like the cleanest solution.
Is there no way of determining the step type?
Thanks again for your time
Steve
Message 9 of 20
(4,731 Views)
Hi Steve,
  sods law - I started generating the attached example about 2:00 and the thread has progressed on a bit from there.
Here's the example anyway. It shows the step type's name that failed, so that should give you a starting point.
I've also included a crude mechanism for the retry too. Bear in mind that the architecture you're trying to acheive cannot simply jump around the place between groups, just 0 to go to the start of the group, and -1 to go to the end of the group.
To restart an entire sequence, you'll need to get out of that sequence to start with, which I suppose would be the point of only doing the retry section if the calling step was a sequencecall type
The attached example can differentiate the step types easily enough. Just need to be careful about which point you ask to restart from - as you've said earlier - restart the step = restarting the subsequence since you're then back up a level where the calling step resides.
Good luck
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
Message 10 of 20
(4,727 Views)
