NI TestStand
Controlling Test Sequence Flow from inside the ProcessModelPostStepFailure Engine Callback
Hi Sacha
Thanks for the zip, unfortunately we are running TS 3.1 here, cant open TS 3.5 Files
Regards
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
Message 11 of 20
(1,970 Views)
oops - forgot - and Ray's post reminded me - that used to be the case about jumping backwards, but you can change the step group as in the attached new example.
Sorry - I'd better look at 3.5 a bit more closely in the future!!!!
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
Message 12 of 20
(1,972 Views)
Hi Sacha
Still TS 3.5
Steve
Message 13 of 20
(1,968 Views)
Timing is everything - here it is for 3.1
Sacha Emery
Message 14 of 20
(1,972 Views)
Just realised - you could more generic by referring to Parameters.Step rather than the Runstate.CallingStep
Good luck
Sacha Emery
Message 15 of 20
(1,964 Views)
Sacha hopeful has answered any outstand questions.
But just to add, you can check the SequenceName in the Callback by using NameOf(RunState.Caller.RunState.Sequence) and this will return the name of the Sequence as a string eg "MainSequence".
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
Message 16 of 20
(1,965 Views)
Thanks guys
Everything is good in the land TestStand 3.1
Thanks for all your efforts
Steve
Message 17 of 20
(1,960 Views)
Can anyone help me with this??
I need to do the exact thing, retry failed tests using the ProcessModelPostStepFailure Callback, but it's not working.
The strange thing, it runs fine if I run it from the TestStand environment, but when launch using my OI, it will not retry the step. It's like the RunState.Caller...StepIndex is not working properly. Doesn't make sense to me. One note, my sequence(s) are built dynamically, but they run just like a normal sequence.
Thanks a lot.
Message 18 of 20
(1,633 Views)
Actual, it doesn't work from Teststand environment either. I think I've been staring at it all too long.
Again, any help is appreciated.
Message 19 of 20
(1,630 Views)
Found the problem!
If "Step Failure Causes Sequence Failure" is checked, the "Retry" does not work.
Message 20 of 20
(1,627 Views)
