NI TestStand
Controlling indention in report file
I am using TestStand 4.0 and generating a text report. I notice (and do not like) that a result from a step is indented in the report file based on the level in the sequence code. For example, results from steps in an flow control block (if, for, while, etc) are indented to the right more than results from steps not in a control block.
Before I edit the reportgen_txt sequence file, am I missing some setting to not have the results indented based on sequence file coding? I looked, but couldn't find any. I would like the results all starting in the first column.
 I'm not sure while there is a correlation between sequence coding style and report formatting.
Don
(3,628 Views)
Hi Don,
It looks like your question has been answered in this post. Please let me know if you have any more questions.
With warm regards,
David D.
(3,607 Views)
