NI TestStand
logout Operator login as Developer
I'm running Test Stand version 3.1, I want to Login as a Developer to a Sequence file already setup for Operators to run.  When I right click on a VI in a step I want to be able to edit that VI. Its my understanding I need to login as a developer...
Still new to Test Stand
Thx ahead of time
OK an update, login as username "admin" and password "developer". I right click bring up the context menu on a VI in the sequence, I can do "Edit Code" on the VI but not "Edit" on the sequence itself... How do I get access to edit the sequence???
Message Edited by richjoh on 07-14-2008 07:48 AM
Test Stand 4.0 I could edit the sequence. Not so sure on doing this within 3.1
Message Edited by richjoh on 07-14-2008 07:51 AM
(3,078 Views)
OK think I found the issue. I must close the running VI before I can edit any code in TestStand... TestStand 101 knowledge. Its only been 6  month of not using TestStand wow.
(3,070 Views)
