Convert an Exponential in TestStand
Is there a way to convert an exponential (1.051058-e7) to a floating point number (0.00000051058) in TestStand?
The value that I'm getting from my external DLL is as a String, but I need it as a number.  Val() returns the exponential as well.
Mike
(3,135 Views)
Val returns a number. The number can be formatted for display as an exponential, or not, but the actual value is the same either way.
If you store the value in a local or use a numeric limit test, you can set the numeric format of the local or limit test to "%.13f" to display it how you desire. If you need the string version of the number in your desired format, call Str(<number>, "%.13f")
(3,127 Views)
