NI TestStand
Converting Teststand sequence file to .xmf format prorammatically
Hi All,
Is it possible to convert the .seq file to.xml format programmatically in TestStand?
I am able to manually create xml file using  Edit >> Sequence file properties option. but  I need this to be done programmatically.
Thank you for any suggestions .
(1,189 Views)
Please read the subject as "Converting Teststand sequence file to .xml format programmatically"..
(1,144 Views)
Looks like there might be a CLI that we can use. See this link:
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/sequence-file-converter.html
I'm going to give this a try since I have the same need.
Steven Dusing
CLA, CTA
(873 Views)
