NI TestStand
Syntax for trim Line Feed
Team,
I have an long text with Line Feed and used "Split" Function with "\n" as delimiter  and i am getting array of splitted array with Line feed in each element.
How to trim line feed character?
Tried using Trim Function but no luck.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(975 Views)
SearchAndReplace(Locals.String, "\r", "", 0, False, -1, False),
SearchAndReplace(Locals.String, "\n", "", 0, False, -1, False)
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(889 Views)
