NI TestStand
Converting Units
Is there a way to have TestStand automatically convert units? (or at least an easy solution to make it convert?)
When I try to do a Numeric Limit Test, I want to compare a measure of time, on the order of nanoseconds. The input comes in as seconds, but I would like the output in the TestStand report, to be in nanoseconds. Is there any way of doing this other than manually converting the input into nanoseconds before doing the limit test?
(3,098 Views)
Hi DanHadi,
Unfortunately, we do not have a function in the TestStand API that performs this operation.  Your best option, like you mentioned before, is to convert the input before passing it to the limit test.
Matt S
(3,079 Views)
