NI TestStand
get the result of testsequence
I wrote a testsequence in Teststand 4.0 and I'm currently using the standart PostUUT of teststand. So at the end of my testsequence I get a messagebox saying "Testsequence Passed" or "Testsequence Failed".
Now I would like to leave this message away, but I still need to know if my sequence was passed or failed. So, is there a way to get the status of testsequence at the end? I would like to know if my sequence was passed or not, and then give this information to my own userinterface.
(3,348 Views)
Are you saying you dont want the banner displayed, if so just override the PostUUT callback and delete the banner steps.
Your OI will already know of your sequence status, are you creating your own OI?
Regards
Ray Farmer
Regards
Ray Farmer
(3,347 Views)
In the PostUUT I want to get the status of the sequence (Passed or Failed). I would then place the result into a variable an pass to my own userinterface.
(3,345 Views)
PostUUT is passed the result container of "MainSequence Callback" step, which is the overall result of your MainSequence therefore in PostUUT you just need Parameter.Result.Status which is the value used in the precondition of the banner steps in PostUUT.
Hope is helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,340 Views)
