NI TestStand
Converting teststand 3.xx -> teststand 1.xx
How can I convert code developed in teststand 3.00 to testand 1.xx
(2,942 Views)
Dear Rash,
This convertion would require a two-step process:
1. Using TestStand 3.0, convert your sequence files into a 2.x format.
2. Using Teststand 2.x, convert it into a 1.x format.
Something to keep in mind is that TestStand 3.x has many more features and enhancements than TestStand 1.x. You might loose some functionality when converting a TS 3.0 sequence file back to TS 1.x.
Carlos L
(2,942 Views)
