NI TestStand
Importing an array of containers with Property Loader
I'm using TestStand 2.0 and am having trouble importing arrays of containers using the property loader... The first array element is copied in ok but the subsequent ones do not (all values are 0).
I'm sure I'm looping through the array ok as I can load in simple arrays of numbers. I only see this problem with arrays of containers.
Is there anything I may have overlooked?
(3,559 Views)
The trouble with importing arrays with the property loader is you have to specify each elements of the array individually.
I have attached an example which I hope helps.
Regards
Ray Farmer
Regards
Ray Farmer
(3,559 Views)
