NI TestStand
Correct termination Banner when run time errors are ignored
When I run a sequence with run-time errors ignored, TestStand continues on to the next step after encountering an error, but invokes PASS banner at end of test. How can I run (with run-time errors ignored) and get the correct banner at the end of test. In other words, if any errors were encountered, I'd like the FAIL banner to come up at the end of the test (actually anything other than the PASS banner would be acceptable).
Hurst
(3,257 Views)
Hi Hurst,
You will need to make the Sequence fail and you can do this by setting RunState.SequenceFailed = True
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,247 Views)
Ray,
Thanks, that method works great.
Hurst
(3,230 Views)
