NI TestStand
may I have install 2 different teststand version in same computer?
Current ,I have two version teststand ,2.0 and 3.1 and each have them lincense,
I want to install into same computer, first ,the 2.0 already installed,when I install
the 3.1,the system is exist 2 version but in the license manager only display the
3.1 license ,how can I keep the two license in same computer ?
thank in advance...
(3,296 Views)
Providing you haven't installed TS3.1 in the same place as TS2.1 then you can have multiple TestStand's on one PC.
Only one TestStand will be active at any one time. There is a version switcher program that you have to run to change the active TestStand.
Hope this helps you.
Regards
Ray Farmer
Regards
Ray Farmer
(3,290 Views)
OK,I got it,thank you.
(3,288 Views)
