I am having an issue when I try to run a Test Stand sequence that calls a CVI DLL. The error I get is the subject of this post.
If I were to put "abc.dll" in the same folder where "123.dll" resides, this error will go away. However, "123.dll" is used in other applications and I don't want to create multiple copies of this DLL for every program or sequence that wants to call it - that could get messy.
Does anyone have any suggestions as to what the issue might be?
Thank you,
Seth Kline
