NI TestStand
Count how many times a step is executed
Hello. Is there a method to count how many times a type of step is executed? I have multiple uses of this type of step so I search for a easier method putting a post-expression at every call of this step.
(2,558 Views)
Is it a custom step type?  If so, you could increment a fileglobal in the post-step of your custom step.
Alternatively, this could be done in SequenceFilePostStep.  something like:
If (RunState.CallingStep.StepType.Name=="Your custom step type")
fileglobals.counter++
(2,535 Views)
Accepted by topic author donnie_og
The execution profiler is also a way you could get this info without modifying the step type or sequence file. This would be an okay method if you only need to get this info periodically (on-demand) rather than after each execution.
If you need it after each execution, why not just use a results processing plug-in? You can make an extra instance of the report generator or database plug-in, and use a filter expression to only log results for your step type.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,527 Views)
