NI TestStand
SystemLink Error -251251
I am new to the SystemLink. I am trying to implement it in my program and view the results on Test Monitor. When I run the program, I get an error as shown in the screenshot below. Surprisingly, when I copy pasted the systemLink code (excluding my own program) in a new vi, it is working fine. It is giving the error only when implemented with my program. What could be the possible reasons?
Thank you!
(2,271 Views)
You should post this on the SystemLink board:
https://forums.ni.com/t5/forums/filteredbylabelpage/board-id/1020/label-name/systemlink
https://www.linkedin.com/in/trentweaver
(2,245 Views)
okay. Thank you for the suggestion.
(2,240 Views)
