Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Create LabView DLL to use from TestStand
Hiren
10-17-2005
04:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a top level vi. I want to create a dll from this vi and use that dll in my teststand test sequence file.
Is it possible to do it? If it is then what is the best approach.
Thank you,
Hiren
Hiren Patel
0
Kudos
Message
1
of 2
(3,118 Views)
Reply
Re: Create LabView DLL to use from TestStand
Dennis_Knutson
Knight of NI
10-17-2005
04:56 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
With the application builder that comes with the pro version or as a separate add-on, you can create a DLL. Keep the parameters simple - see
here
0
Kudos
Message
2
of 2
(3,110 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
