NI TestStand
Create LabView DLL to use from TestStand
I have a top level vi. I want to create a dll from this vi and use that dll in my teststand test sequence file.
Is it possible to do it? If it is then what is the best approach.
Thank you,
Hiren
Hiren Patel
(3,192 Views)
With the application builder that comes with the pro version or as a separate add-on, you can create a DLL. Keep the parameters simple - see here.
(3,184 Views)
