NI TestStand
Create VI option is disabled
I'm new to Teststand and I'm going throught the "Using LabVIEW with Teststand" tutorial. I'm trying to create a VI from teststand but the Create VI icon is greyed out. Any idea of possible causes?
I'm logged as an administrator and I'm running Teststand 4.2 Development System with LabVIEW 8.6 Professionnal Development System
(3,630 Views)
Accepted by topic author ben64
Select Configure>>Adapters...
Select LabVIEW and click the Configure button.
Make sure the Development System radio button is selected.
(3,627 Views)
I don't have TestStand 4.2 at the moment but my guess is you are using the LabVIEW runtime adapter instead of the Development Environment adapter. In 4.1 this is located on the top tool bar under configure>>adapters>>then select LabVIEW>>and press configure button. Select Development System and press OK.
Hope this helps.
Beat me to the punch by 2 min. Smiley Happy
Message Edited by GovBob on 08-13-2009 03:30 PM
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,624 Views)
Thanks to both of you, that solved the issue.
Ben
(3,619 Views)
