NI TestStand
TestStand does not TestStand does not continue after vi terminates with error
I ran into the strangest thing the other day, i have a vi written in 8.6.1 that i've sequenced in teststand 4.1.1 it works great, unless i pass out an error. then teststand doesn't seem to realize the vi has terminated, the error i'm passing out is custom, cluster contains a error code 5000, boolean value of true, and a string stating that it was unable to connect. let me see if i can attach it, it's made to be sequenced, so you may have to modify the inputs a bit to get the vi working right.... thanks for any feedback. you will need both vi's as one is embedded in the other.
Kris
(3,812 Views)
You have to actually connect the error to the error out!
Regards
Ray Farmer
Message Edited by Ray Farmer on 08-13-2009 09:09 PM
Regards
Ray Farmer
(3,799 Views)
Yeah, sorry i did try that, among other options for passing one error out or all, nothing seems to work...
I did try it again after your suggestion for a sanity check, to no avail. the thing that gets me is that it works fine when there's no error.. grrrr.
(3,791 Views)
Can you post an example sequence file that uses this VI which highlight the problem.
Regards
Ray Farmer
Regards
Ray Farmer
(3,775 Views)
odd, i think i know what the problem is just not how to fix it. i pulled the sub-sequence out to attach it here, modified it to work alone, and problem solved. let me explain a little more on this test...
I'm using a vi as a GUI that gets pull up in a main sequence, using a notifier i pass the test (sub-sequence) name out from the GUI to teststand, once teststand is notified of the change, it runs the specified sequence. as the problem manifests it's self in a subsequence, i don't think that the error is getting passed from the sub to the main. any ideas? thanks again.
Kris
(3,768 Views)
