NI TestStand
How to create SyncManager object in csharp
Greetings!
I'm tryint to send a notitication to a testStand sequence from a charp DLL ... it seems I should use the SyncManager, but I can't figure out where the syncmanager object is defined:
xxx foo = seqContext.Engine.GetSyncManager("myNotification");
The problem is that I cannot determine what the type 'xxx' should be.  I would have thought it would be a "SyncManager", but this does not seem to be a valid type.
I am referencing:  NationalInstruments.TestStand.Interop.API and NationalInstruments.TestStand.Interop.UI
What is the correct type?
Tom M.
(4,006 Views)
Accepted by topic author LabCat
Hi Tom,
you have add the TSSyncLib.dll as COM Object to your c# Project
Then it should work
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,989 Views)
Thanks!  That was what I needed!  I didn't see any reference to this DLL in the parts of the documentation that I read.  I guess I need to read it all!
Tom MacLean
(3,973 Views)
