NI TestStand
Custom Batch Process Model - Single Pass - Batch Report
I modified the batch process model and created my own custom batch process model.  I added my own serial number input methods.  In my teststand application, I am using "Single Pass" execution mode and I would like to keep it that way.  I am having a problem with the Batch Report.  The Batch report will not populate when I hit "Terminate All" when my main sequence is running.  However, the batch report will populate and display if I let the main sequence run thru completely.  I noticed in my process model that it will not execute past the "Wait For TestSockets -- PostMainSequence" in the "Single Pass" sequence in my custom process model but will continue past the "Wait For TestSockets -- PostMainSequence" if I allow my main sequence to run completely thru.  I am not sure if that is significant or not but just an observation.  Basically, how can I get the batch reports to populate and display with a batch process model in "Single Pass" execution mode?
(2,155 Views)
To be more clear...  Why won't my batch report populate and display when using the batch process model in "Single Pass" execution mode after I hit "Terminate All"
(2,078 Views)
