NI TestStand
Pass parameter to RT sequence numeric limit test
Hi there,
I met several problems when trying to pass parameters into Veristand "RT sequence numeric limit test" step. We are using Teststand 2017 and Veristand 2018. The Teststand sequence includes three steps: Initialize Veristand, RT sequence numeric limit test, and stop Veristand. The numeric limit step is linked to a stimulus profile sequence, which take a numeric value as parameter and return a numeric value. There are two problems I am curious about:
1. When I link the sequence, I can configure the number to pass in. But It only works when I have Veristand fully closed, basically no window of Veristand is running. As long as I have Veristand running, even just the start window, the numeric limit test will return default value and report test failure.
2. When I configure the input parameter to a local variable in Teststand sequence, it always fail no matter if Veristand is open or not.
Message 1 of 1
(2,006 Views)
