NI TestStand
Custom C#-OPUI - Are TestStand.Interop.* -references hardcoded?
i created an OPUI in Visula Studio 2012 C# which references from TestStand 2013 this:
NationalInstruments.TestStand.Interop.API
NationalInstruments.TestStand.Interop.UI
NationalInstruments.TestStand.Interop.UI.AxControls
NationalInstruments.TestStand.Interop.UI.Sopport
Everything is running fine under Windows 10 64bit.
Now i have the problem that my OPUI is not running with TestStand 2014 (64bit).
Do i simply have to replace the four references and recompile and everything is good?
The TestStand-process is starting (becaue i see the 7 days-evaluation window) but after i start the testplan i get:
Default Critical: 0 : System.Runtime.InteropServices.COMException (0xFFFFBC6B): Index out of range.
   bei NationalInstruments.TestStand.Interop.UI.ISequenceFileViewMgr.GetCommand(CommandKinds cmdKind, Int32 Index)
   bei NationalInstruments.TestStand.Interop.UI.Ax.AxSequenceFileViewMgr.GetCommand(CommandKinds cmdKind, Int32 index)
Is there any other way so that i can use any TestStand-version or do i always have to recompile?
(4,249 Views)
Hello OnlyOne,
i have a feeling you need to recompile the UI to a 64 Bit process. As far as I understand you build a UI for TS2013 and you would like to reuse it to call TS 2014 64 Bit. You are trying to call a 64 Bit process (TS Engine) from a 32 Bit process. This does not work and it could explain the "index out of range" error since you can not access all of the 64 Bit process' memory.
Disclaimer: I'm not too familiar with C# and Visual Studio.
Kind regards
AndGar
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(4,230 Views)
