NI TestStand
[TS->LV] How to read local variable after execution ?
my sequence have a local variable named 'Txt_uut_out'
that holds a scanned serial number read from within the
sequence flow. However, I'd like to read that given local
variable from Labview.
I have access the the folowwing contexts :
Engine
Sequence
Sequence context
Sequence model
Execution
I tried the two (three) following methods, but none of them
works like expected :
Any idea ?
David Koch
(4,511 Views)
Hi David,
It is hard to try anything without the code. I would suggest looking at TestStand's built-in examples. They are typically installed in a location such as: "C:\Users\Public\Documents\National Instruments\TestStand 2014\Examples" If you look into the folder "StructPassing\LabVIEW" and open the "Cluster Passing to LV VI.seq" file, this will provide a good example of how to pass data between LabVIEW code module steps. In each action step, you can see that TestStand is calling a LabVIEW code module and passing it local variables as inputs and storing the outputs of the VI call in other local variables. The values stored in these local variables are saved between steps.
You can also find usefull information here :
Using Functional Global Variables to share data between the TestStand Operator Interface and Code mo...
Pass Container in a Queue from TestStand to LabVIEW
How to pass sync steps from TestStand to LabVIEW?
M-Junior
(4,479 Views)
Thanks for the input.
Somewhere within the sequence, I fill a local variable
named 'Txt_uut_out' and I just want to read it at the end
of the sequence execution.
Obviously I might have missed the right Sequence
context and I'm wondering which one I have to read,
the one provided at the beginning of the execution
or the one you could get from Thread[0] and call the
GetSequenceContext method.
I provided the code as screenshots.
David Koch
(4,473 Views)
