NI TestStand
Custom Front End Callback
I'm customizing the LoginLogout Front End CallBack in TestStand 2010, it works when I call it from my custom OI (LV2010). But when I launch TestStand, I get an error message (the error code doesn't seem to be documented). I cannot log in or out. If I remove the callback from the public directory, and use the NI callback everything's back to normal.
Does anyone know what I am doing wrong? or can reproduce the error?
I have LV 2010 f2 installed (not SP1 yet)
Thank you,
Rodéric L
Certified LabVIEW Architect
(3,320 Views)
Accepted by topic author Rodéric
I solved my problem simplifying the VI, and moving my variable to the end of the container, I also moved to LV2010 SP1. I get some reference leak issues and sometimes there is a pop up coming saying the sequence file wasn't properly relased
Rodéric L
(3,286 Views)
