NI TestStand
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Custom Step Type: Sequence Call
OK, I'm primarily a LabVIEW programmer, but in TestStand I understand how to:
* Create a Custom Step Type
* Link a LabVIEW Module for execution, post substep, edit substep, etc.
* Prevent the user from selecting a different module for an instance of my Custom Step Type.
All good stuff.
Now here's what I want to do: the exact same thing, except that I want the custom step to call a subsequence instead of a LabVIEW VI during execution. Yes, I want to use a LabVIEW VI for the edit substep (to set certain parameters for this instance of the subsequence call. Yes, I want to use a LabVIEW VI for the post substep.
Can this be done?
(5,374 Views)
Short answer, yes.
When you create your step type, for the Specify Module you would use a SequcenceCall Adapter instead of your labview adapter.
You would have to have your sequencefile with your sequences already created seperately and you would set the sequencefile not to use a process model in the sequencefile properties.
Regards
Ray Farmer
Regards
Ray Farmer
(5,368 Views)
Great!
Only problem is: I don't see any "Sequence Call Adapter". I am looking on the General tab of the Custom Step Type Properties, under "Designate an Adapter". Sequence Call is not an option. (I am using TS3.5)
When I select "None", which was my other guess, then the "Specify Module" button disappears.
How exactly do I set it up?
(5,363 Views)
10 Things,
The reason you do not see the sequence call adapter is because it is hidden by default.
Go to Configure->Adapters and uncheck the 'Hidden' check box for the sequence call adapter.
Regards
Antonio Lie
(5,357 Views)
Great, thanks. I'll try it out...
(5,341 Views)
The answer from Antonio Lie above should be marked as the answer/resolution to the question
(2,726 Views)
