NI TestStand
Custom TestStand Interface with Dynamic Subpanels and Packed Project Libraries
In the example below, you can insert VIs into an interface's subpanel if it's an absolute path or if it's in a project.  Does anyone have an example where a VI is in a packed project library and then the VI is inserted into a subpanel?
https://forums.ni.com/t5/Example-Code/Dynamic-LabVIEW-Subpanel-in-a-TestStand-User-Interface/ta-p/36...
So in TestStand, the VI path might be c:\ppl.lvlibp\test.vi
How do I get test.vi into my subpanel using similar code to the example?
(2,095 Views)
Just call it the same way you call a normal vi.It does not have to be an absolute path specified, the vi's will take care of that on their own. As you can see from mine I'm using a relative path. Like this:
That worked for me.
(2,032 Views)
