NI TestStand
Custom UI
Hi everyone,
I’m developing a custom TestStand step type and exploring ways to provide a custom configuration panel for it.
Currently, I’ve built a Qt-based DLL (using ShowSettingsPanel() in C++) that opens a popup dialog for step configuration.
I understand that TestStand allows configuration UIs through ActiveX, .NET, or CVI DLLs via the Edit Tab Controls feature. However, I’m wondering if it’s technically possible to embed a custom UI (like a Qt panel) directly inside the Step Settings tab (similar to how the built-in “Call Executable” or “Message Popup” steps show their controls).
Message 1 of 9
(1,995 Views)
Can't ultimately really answer your question, yet you can find the source code for the built-in steps / step settings in the subfolders of %TestStand%\Components\StepTypes.
Maybe this helps
Message 2 of 9
(1,989 Views)
Thank you for your reply!
I’m currently exploring the approach you suggested by checking the source code under the %TestStand%\Components\StepTypes subfolders.
Message 3 of 9
(1,987 Views)
You need to build the Edit Tab for the custom step in WinForms only.
Santhosh
Soliton Technologies
Message 4 of 9
(1,963 Views)
Thank you for your reply.
As of now, using the Edit Tabs option in my custom step type, I’m able to add a tab and include a button inside it — which I can use to launch my configuration dialog.
So does that mean using .NET WinForms, it is actually possible to make a fully embedded configuration tab (with controls directly inside the tab) — similar to the built-in steps like Call Executable or Message Popup?
Message 5 of 9
(1,954 Views)
Accepted by Nowful
Yes, you can build complex Edit Tabs using WinForms.
Please refer to Creating Custom Step Type Edit Tabs in the Sequence Editor - NI
and here is the example code https://download.ni.com/evaluation/teststand/customstepeditpanel.zip
Santhosh
Message 6 of 9
(1,932 Views)
Thank you for your reply, Santhosh.
I tried the method you suggested, but it’s showing an error. I’ve attached the error img here for your reference — could you please take a look and let me know what might be causing it?
Thanks in advance!ff117eef-7bfa-4967-99e6-815367809825.pngff117eef-7bfa-4967-99e6-815367809825.png
Message 7 of 9
(1,904 Views)
Hi Santhosh,
Thank you so much for your kind information and guidance. I was able to fix the issue, and it’s now working exactly as expected. I really appreciate your support and detailed explanations!
Message 8 of 9
(1,895 Views)
@Nowful wrote:
Hi Santhosh,
Please share the issue and fix so that anyone trying to replicate is also benefitted.
Santhosh
Message 9 of 9
(1,884 Views)
