11-11-2025 06:30 AM
Hi everyone,
I’m developing a custom TestStand step type and exploring ways to provide a custom configuration panel for it.
Currently, I’ve built a Qt-based DLL (using ShowSettingsPanel() in C++) that opens a popup dialog for step configuration.
I understand that TestStand allows configuration UIs through ActiveX, .NET, or CVI DLLs via the Edit Tab Controls feature. However, I’m wondering if it’s technically possible to embed a custom UI (like a Qt panel) directly inside the Step Settings tab (similar to how the built-in “Call Executable” or “Message Popup” steps show their controls).
Solved! Go to Solution.
11-11-2025 06:36 AM
Can't ultimately really answer your question, yet you can find the source code for the built-in steps / step settings in the subfolders of %TestStand%\Components\StepTypes.
Maybe this helps
11-11-2025 06:42 AM
Thank you for your reply!
I’m currently exploring the approach you suggested by checking the source code under the %TestStand%\Components\StepTypes subfolders.
11-11-2025 07:06 AM
You need to build the Edit Tab for the custom step in WinForms only.
11-11-2025 07:19 AM
Thank you for your reply.
As of now, using the Edit Tabs option in my custom step type, I’m able to add a tab and include a button inside it — which I can use to launch my configuration dialog.
So does that mean using .NET WinForms, it is actually possible to make a fully embedded configuration tab (with controls directly inside the tab) — similar to the built-in steps like Call Executable or Message Popup?
11-11-2025 09:13 AM - edited 11-11-2025 09:14 AM
Yes, you can build complex Edit Tabs using WinForms.
Please refer to Creating Custom Step Type Edit Tabs in the Sequence Editor - NI
and here is the example code https://download.ni.com/evaluation/teststand/customstepeditpanel.zip
11-12-2025 03:39 AM
Thank you for your reply, Santhosh.
I tried the method you suggested, but it’s showing an error. I’ve attached the error img here for your reference — could you please take a look and let me know what might be causing it?
11-12-2025 05:31 AM
Hi Santhosh,
Thank you so much for your kind information and guidance. I was able to fix the issue, and it’s now working exactly as expected. I really appreciate your support and detailed explanations!
11-12-2025 06:17 AM
@Nowful wrote:
Hi Santhosh,
Please share the issue and fix so that anyone trying to replicate is also benefitted.
